You would need to post you NC-Program code and cutter diameter for an analysis.
Maybe a simple drawing of what you think you cutter path should look like would help
Hi all,
I have a problem, when i cut mdf board 18mm and deeping for 2mm, every time when goes around, it is back to y-axis 0, he start not from the same position. And that's every time. There is a Mach3 software show that goes to zero, but it really isn't.
I used a Stepperoline DM542T, and a Stepperoline 23HS45-4204S engine.
Can somebody help me? Thank's
- Problem- SteelTailor Portable CNC cutting machine ,the X axis is cutting 4mm bigger?
- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
- New Machine Build- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
- Just IN- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
The part could be moving or the machine might be losing steps if you have given it a feed rate that it doesn't have the power to execute.
