I am having an issue with Mach3 on my home-built CNC. My machine working area is X – 100 inches by Y – 54 inches by X – 12 inches. With my soft limits on and I try and run a program that exceeds the machine coordinates of X > 73.6 inches it says, “Soft Limit Exceeded” and the machine hard stops. My Soft Limit on the X Axis is set to 100 inches and I can shuttle it to 100 inches. I can turn off soft limits and run any program over X > 73.6 without an issue.
I have recreated the XML configuration for my machine three times to see if it was something I had done. Several times with just the most basic settings and the issue persists. I have even opened a case with ArtSoft and all they said was to reinstall the software, which I did on two different PCs and still not working. I would like to resolve this issue as it would make running the machine more convenient and safer.
Any recommendations would be appreciated.
Machine Specs
Windows 10 8gb RAM Dedicated PC
Mach3 Version R3.043.062
Mach3 2010 Screens
PMDX-126 controller
PMDX-107 for VFD
Gecko G201x
Warp3 ESS
