Changing the feedrate / spindle increment buttons percentage
Results 1 to 2 of 2
Thread: Changing the feedrate / spindle increment buttons percentage
    Member Insect's Avatar
    Apr 2020
    Default Changing the feedrate / spindle increment buttons percentage
    So the increment buttons on the controls for rates are 25%, I want them to be 2% for my application. It is very useful to make 2% changes to cancel harmonics, and even make minor feedrate changes... 25% is way too much most of the time.
    I can't find a way to change this, any ideas?
    May 2010
    Default Re: Changing the feedrate / spindle increment buttons percentage
    In the Mach3 Config \ General Logic Configuration, on the far right side there is a 'Spindle OV increment' setting which can be changed.
    Not sure about the feed rate, but mine seems to go at 10% steps.
    Just found and old MachSupport post
    https://www.machsupport.com/forum/in...?topic=12503.0
    that has some suggestions... I haven't tried them.
