Problem Strange behaviour trying to backoff more from homng switch.
Results 1 to 1 of 1
Thread: Strange behaviour trying to backoff more from homng switch.
    Default Strange behaviour trying to backoff more from homng switch.
    Hi guys,
    I have inductive NPN NC sensors for homing and limit (shared).
    When Z axis do the homing procedures, it doesn't backoff enough (and/or quick enough), so the axis backs off until a tiny zone in witch the switch triggers on and off.
    All cables are shielded and grounded on one side, this happens even with VFD disconnected, and when the spindle is at maximum the switches doesn't trip. Debounce at 2500.
    I tried a VB script to back off more, moving fast the homed axis away, up to the Axis absolute machine zero (I have homing offesets). And however this is something I would like to have apart from preventing the Z issue.
    I tried a script found on the internet and the Z works ok (in fact, the entire homing goes ok, each axis homes and then moves away fast).
    But after performing this script, the controller doesn't allow me to ZERO the axis and doesn't accept MDI commands. In order to fix this I have to push RESET several times (sometimes works, sometimes it doesn't).
    A axis is non rotary and slaved to Y, each with his own homing switch.
    Code used:
    Code:
    DoButton( 24 ) 'Ref Z
        While IsMoving
        Wend
        Code " G53 G0 Z0 " 'moves Z to machine 0
        While IsMoving
        Wend
        DoOEMButton(135) 'Zero Z
    DoButton( 22 ) 'Ref X
        While IsMoving
        Wend
        Code " G53 G0 X0 " 'moves X to machine 0
        While IsMoving
        Wend
        DoOEMButton(133) 'Zero X
    DoButton( 23 ) 'Ref Y
    DoButton( 25 ) 'Ref A
        While IsMoving
        Wend
        Code " G53 G0 Y0 " 'moves Y to machine 0
        While IsMoving
        Wend
        DoOEMButton(134) 'Zero Y
    It's like it remains hanging in a While IsMoving, or something. Later I'll try mess around with a friend who used VBA a lot in the past.
    Strange behaviour trying to backoff more from homng switch.-general_config-png Strange behaviour trying to backoff more from homng switch.-homing-limits-png
    Attached: XML config file and some screenshots.
    SETUP:
    Mach 3
    Version R3.043.062
    Win 10 x64
    NUVM V2 Controllor with latest plugin
    DM542 stepper drivers, 200°/rev steppers ; 2000 steps per millimeter
    A axis slaved to Y axis,
    UNITS: MILLIMETERS
    Attached Thumbnails Attached Thumbnails Strange behaviour trying to backoff more from homng switch.-general_config-png   Strange behaviour trying to backoff more from homng switch.-homing-limits-png
    Attached Files Attached Files
