This requires you to add a DRO to the screen for your toolsetter thiockness.GageH = GetUserDRO(1152)
Try including the thickness in the macro, like this:
GageH = 25
Hello all
I have a problem make auto tool zero in Mach3
I use mach3 Version R3.043.066 and usb 5Axis green board
Can't working
Thank and advance
Code
'Rem Probe Down by PEU (Based on Erniebro Work)
FeedCurrent = GetOemDRO(818) 'Get the current settings
ZCurrent = GetDro(2)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "F1" 'slow feed rate to 10 MM/MIN
GageH = GetOEMDRO (1002)
Rem Probe Down by PEU (Based On Erniebro Work)
ZCurrent = GetOemDro(802)
ZNew = ZCurrent - 30 'probe down 30mm
Code "G31 Z" &ZNew
While IsMoving()
Wend
Call SetDro (2,GageH)
FinalMove = GageH * 1
Code "G0 Z" &FinalMove
Code "G0 Z" &30
Code "F" &FeedCurrent 'restore starting
GageH = 25
UCCNC 2017 Screenset
Thank you.
