Newbie need help tunning step motors
Results 1 to 3 of 3
Thread: need help tunning step motors
    Member Hillbillydeluxefab's Avatar
    Feb 2021
    Question need help tunning step motors
    hi i am a complete newbie at setting up a cnc. i have ran one for work for the past 6 years but never set up a new one.
    what i have is a home made plasma table 5x5.
    i run the mach 3 software
    the problem i have is my x and y axis step motors run very jerky and make grinding noises and not even close distance its supposed to.
    all three motors are nema 23
    x and y are belt driven to i believe a 3 to 1 reduction i have not counted the teeth yet.
    any help would be appreciated
    Apr 2004
    Oakland CA USA
    Default Re: need help tunning step motors
    Could you share some more details about your setup, like what drives you're using, what settings you've chosen, what the specific motors are you're trying to drive, what is transmitting the power to them (eg: screws, rack and pinion) what you're using for slides, and why you decided to use a 3 to 1 reduction? Does this always happen, or just when your plasma cutter is on?
    Andrew Werby
    https://computersculpture.com/
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    For the beginning, enter motor tuning and lower velocity and acceleration and start from there.
    On Mach forum you can find a ton of documentation.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
