Photoelectric encoder with mach3 turning
Results 1 to 18 of 18
Thread: Photoelectric encoder with mach3 turning
    Dec 2013
    Default Photoelectric encoder with mach3 turning
    Photoelectric encoder with mach3 turning-capture-6-jpg
    I have got a 3 pin Photoelectric encoder like this
    and i was wondering if it is possible to use it to encode my lathe spindle with mach3
    but how the start of the single point threading will be detected?
    thanks
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Photoelectric encoder with mach3 turning
    Mach3 only needs 1 pulse per rev for threading. It can't use an encoder.
    UCCNC 2017 Screenset
    Dec 2013
    Quote Originally Posted by ger21 View Post
    great, is that accurate enough?
    thank you so much
    Member machinehop5's Avatar
    Aug 2009
    ...is it Rigid Tapping you're thinking about?
    https://www.cnczone.com/forums/novak...witch-bob.html
    Dec 2013
    Quote Originally Posted by machinehop5 View Post
    as mentioned single point threading
    but to be honest rigid tapping can be another extra question, i am assuming it will be much more challenging , you think it can work with a single pulse / rev?
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Graphicman View Post
    A single pulse works fine for threading or rigid tapping, it is just used to synchronize the spindle with the axis, you can just make a disc with a single slot or up to 4 slots which must be machined precise if you do more than ( 1 slot ) Mach3 can use more that ( 1 ) slot, but this can slow it down the more slots it has, In the real-world of Encoder use it is called an ( index pulse or Z pulse ) which all Encoders have for all cnc machines, and for other Encoder use as well, machine homing is all done with a single index Pulse, so this is nothing new to use a single pulse for positioning or synchronizing ( 2 ) axis
    So you could mount a cheap Encoder that has an Index Pulse and you have nothing to make, you can see in this encoder disc the single slot Z Pulse marker
    Attached Thumbnails Attached Thumbnails Photoelectric encoder with mach3 turning-index-slot-png
    Mactec54
  7. #7
    Dec 2013
    I think more than one slot will be needed for rigid tapping to sync the rotation with the feed, but if I used this setup how the single point threading will work as well? how mach will know the start of every pass?
  8. #8
    Dec 2003
    I have got a 3 pin Photoelectric encoder and i was wondering if it is possible to use it to encode my lathe spindle with mach3
    thanks
    You could either make another single slot disc up for the Opto you have or block/cover them all except one.
    To simulate true synchronized threading, you require a controller that can use electronic gearing, where the Z axis etc, is electronically geared off of a spindle incremental encoder.
    For DIY, Galil Motion does this, as does Dynomotion shown in the forum here.
    Dec 2013
    is it possible to single point thread manually on mach3?
  10. #10
    Jan 2005
    If you think it is not going to work for, but has for hundreds of users before, you then could change your control and get the Acorn control which can use an encoder for threading and rigid tapping
    Eding CNC control are working on a full encoder connection they to have a single pulse for threading and rigid tapping
    Acorn is the easiest to connect encoder threading and rigid tapping for a lathe control
    Here is a Mach3 video using a single pulse with a sensor he made and sells, but any single pulse method will work
    Mactec54
  11. #11
    Jan 2005
    What would be the point Mach3 would not be doing anything if you where doing it in manual operation
    Mactec54
  12. #12
    robertbrown2's Avatar
    Dec 2020
    You may be interested in ultrasonic sensor like HC-SR04. You can use it with Arduino in easy way. Here is a good example.
  13. #13
    Dec 2013
    sure, i have seen all these videos it works, but if the spindle is not capable enough or the tap is big enough there will be issues with only 1 pusle/rev for rigid tapping correct?
    I dont see any reason for mach3 not to do its job in manual mode, all that is needed is to gear axis electronically (feed/rev and start), it will just makes things much faster and easier for single projects
  14. #14
    Feb 2008
    Yes, with only one pulse per turn, the controller would have to estimate the spindle angle, this would get worse with larger taps
    and larger load changes generating speed variations that the controller cannot "see". Even guessing the reversal point is going to be pretty
    iffy with 1 pulse per turn
  15. #15
    Dec 2013
    Quote Originally Posted by PCW_MESA View Post
    exactly that is what i am trying to say
  16. #16
    Aug 2009
    ...or do it old school
    https://www.google.com/search?client...=threading+die
    acorned
    https://www.ebay.com/sch/i.html?_fro...n+die&_sacat=0
    works great in a power failure..or 911 doesnot work too
  17. #17
    Jan 2005
    Let us know how this works out for you, ( manual mode, all that is needed is to gear axis electronically ( feed/rev and start )
    That is why I said you have choices Acorn control you can use a regular Encoder spec's below
    Attached Thumbnails Attached Thumbnails Photoelectric encoder with mach3 turning-encoder-specs-png
    Mactec54
  18. #18
    Dec 2013
    I am not intending to change my controller
    if you know a way to let mach3 lock feed/rev plz let me know, otherwise I will not bother to try
    thanks
