You can try modifying the homing macro to use RefCombination to home the slaved axis.
If that doesn't work, then there's a good chance you motion controller does not support slaved homing.
Good day gentle people.
I am building a new plasma cnc table to replace my old table.
A quick overview of the build
NVEM network controller
Closed loop stepper motors Hbs86h driver
Limit switch for all axis
A Axis is slaved to Y axis
Machine moves well and is calibrated.
Here is my problem
With homing with master limit turned OFF in general config.
When I reference all home
The y axis moves to limit switch stops and A Axis does not square up. The system appears to hang. If I activate the A Axis limit manually. It goes green in diagnostic page.
It appears that once the y axis has hit the limit switch. It is waiting for
The A limit switch
But A Axis does not move.
X Axis does not home.
If I turn on home with master in general config.
The homing works fine for all axis.
But no squaring up.
I have set the soft limits page.
On the soft limits page. A and Y axis are set the same.
I would expect that of this was wrong. They would drive in opposite direction when homed.
I have looked on many forums and tried multiple settings.
But can't seem to get this working
Any suggestions appreciated.
VDC
UCCNC 2017 Screenset
