Tell me, I have a CNC plasma cutter controlled by mach 3, I need to turn off the TNS 2 seconds before the end of cutting, can this be done through brains? if so how?
What is TNS? You can control anything that can be turned on or off via a relay by adding the correct code to your cut file. Software like Sheetcam can make doing so fairly simple.
