Jogging motors
Results 1 to 7 of 7
Thread: Jogging motors
    Member Skipio1's Avatar
    Jul 2020
    Default Jogging motors
    Hello all.
    Is it possible to jog the motors in mach3 demo version. Thanks in advance.
    Dec 2013
    Default Re: Jogging motors
    I think so, you have to set the HotKeys as I recall.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    if jogging is enabled it is certainly possible to jog....wouldn't be much of a CNC solution if it didn't.
    Craig
    Member CitizenOfDreams's Avatar
    Nov 2012
    I believe Mach3 demo jogs exactly the same as the licensed one. Just install the program, configure ports/pins and use the arrow keys for jogging. No hotkeys required.
    Or did you mean something else like using a jog wheel controller?
    Jul 2020
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks for your reply, my problem is I bought a 3040T machine but received no instructions on setup. Found a YouTube video how to configure so did all it said but nothing moves. Running Mach 3 demo on windows 7 32 bit. ????????????????????????????
    Nov 2012
    Quote Originally Posted by Skipio1 View Post
    As I understand, "3040T machine" can mean pretty much anything in Aliexpress-speak, so the video you found is not necessarily relevant.
    If it has a USB controller, make sure you have the correct Chinese USB driver for that particular controller. Ask the seller where to download one if it did not come with the machine.
  7. #7
    Jul 2020
    Thanks mate I’ll email them
Jogging motors
Jogging motors
