RnRmotion xml
Results 1 to 4 of 4
Thread: RnRmotion xml
    Apr 2011
    Default RnRmotion xml
    I am trying to get this motion board to work. The pc is communicating with the board but I am getting no motor movement. The inputs are working but do not show up in Mach3. I purchased the board from build your own cnc and downloaded the xml file from their website. I am not sure it is right. Does anyone have a xml file that is working with this board?
    Nov 2013
    Default Re: RnRmotion xml
    you are one of thousands who have that board and have struggled to get it to work.
    Do yourself a favour and buy a US or European made board like an Ethernet SmoothStepper or UC300. They work as advertised
    and most importantly the manufacturer will help you to get it to work.
    Craig
    Apr 2011
    I think you are right. Seems like every time I open Mach3 there is a different problem. Tech support is lacking too.
    Nov 2013
    Lacking???? Try non-existent.
    The appropriate way to signal to the Chinese, or in fact any manufacturer, that we don't want crap and we do want support is to
    not buy their s****t.
    Craig
RnRmotion xml
RnRmotion xml
