Program getting stuck on m3
Results 1 to 2 of 2
Thread: Program getting stuck on m3
    Oct 2017
    Default Program getting stuck on m3
    Hey everyone, hope you are all doing great.
    I’m having an issue where I will run a program and it will run fine for maybe 1 run, maybe 20 runs. Sooner or later it will get stuck on line 3 and never do anything. If I stop the program and reload it, it won’t work. The only way to get it working again is to reload Mach 3.
    I’m calling the gcode that bobcad gives me a “program”.
    If it gets stuck on line 3, the status will usually say which end mill I’m using. If I just hit start run again like I would if I changed tools, nothing happens.
    I’m not really sure what’s going on. Any help or advice is greatly appreciated.
    Attached Thumbnails Attached Thumbnails Program getting stuck on m3-14879f66-9250-42a1-8240-09dd97782379-jpeg   Program getting stuck on m3-d25913ce-56cd-468b-933b-cb323cae699a-jpeg
    Nov 2013
    Default Re: Program getting stuck on m3
    try putting the macro M03 on a separate line.
    Craig
