Mach3 Tool Table
Results 1 to 2 of 2
Thread: Mach3 Tool Table
    Mar 2016
    Default Mach3 Tool Table
    , John DiMarino <jdm1206@aol.com> wrote:
    Up to now I have been cutting using contour for all my machining needs . I wanted to start using "V carve" instead . The CAM software (Carbide Create) request that I select a V Bit with either a 90° angle Tool #301 or a 60° angle Tool #302 which in this case is #302 and generated the Gcode (M6 T302) . After loading the Gcode into Mach 3 , I receive the following message.
    Selected Tool slot number too large, Block=M6 T302 Line 7
    My understanding is that in the Mach3 Tool Table slot number, is associated to the corresponding Tool Number. My question is, how do I add the Tool Number 301 to the Mach3 table when the maximum number of slots are 253.
    I greatly appreciate any assistance you can provide me with .
    John
    Mar 2003
    Shelby Township
    Default Re: Mach3 Tool Table
    Change the number in Carbide Create.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
Mach3 Tool Table
Mach3 Tool Table
Mach3 Tool Table
