XML files
Results 1 to 4 of 4
Thread: XML files
    Aug 2009
    united states
    Default XML files
    When I go to start up mach 3, I go to mach 3 loader, then select the XML file for the DMM breakout board I'm using, and mach 3 then loads up.
    I'm using an ESS and 2 DMM breakout boards
    I'm adding a c10 board to another port on the ESS. The c10 board has an xml file for it. Its been awhile since I set up mach 3. My question is where do I put the xml file for the c10 board? A certain folder?
    Mar 2003
    Shelby Township
    Default Re: XML files
    You can't use multiple .xml files. If you're adding the C10 to your existing system, you'll need to manually enter the port and pins.
    .xml files go in the Mach3\ folder
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Aug 2009
    united states
    oh so basically if I plug c10 board into the ESS port 3, I just have to enter port 3, pin # for whatever I'm connecting to the board? I didn't realize xml files just make it so you don't have to manually input the ports and pins.
    Thanks for the info
    Mar 2003
    Shelby Township
    Basically, yes.
    The .xml file contains all of your Mach3 settings. So if you switch to a new .xml for the C10, then you lose all the previous settings for your current setup.
XML files
XML files
XML files
