Need Help! Is there a way to test #2 port for mpg
Results 1 to 12 of 12
Thread: Is there a way to test #2 port for mpg
    Member Michael82's Avatar
    Nov 2007
    Default Is there a way to test #2 port for mpg
    Hello guys
    I came across a video on build your own cnc.com and he was testing the main#1 printer port as seen in the video . I was wondering can and should this method work for testing the 2nd /#2 printer for a mpg?
    here is video where he is testing his printer port with mach 3 to see if mach3 is seeing the pins and the numbers of the pins to see if they are working together can this work for the 2nd port? Please guys can someone let me know if this will work for testing the 2nd port?
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Default Re: Is there a way to test #2 port for mpg
    This one should work
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Nov 2007
    Quote Originally Posted by ZASto View Post
    Thanks zasto I have something alot like this but I was wanting something more to test mach3 and the 2nd printer port to see if the port is listening to mach 3 . I used the parmon tester to monitor and change the settings but for some reason my pc or my pci card is changing back to the original settings after the pc is shut down . I have changed my bios I changed it in my device manager but it still goes back to the settings that dont work for mach. This is why i was looking for a method to test each pin to see if it does what mach3 is telling it to do
    Nov 2007
    Quote Originally Posted by Michael82 View Post
    Hello guys
    Nov 2007
    In the test in the video what does it mean if I get 5 volts no matter the pin number and no matter the direction I push in mach3 to the positive or the negative it is still 5.03 volts ??? Does this mean the port is not responding ??
    Nov 2007
  7. #7
    Nov 2007
    Ok this is where I'm at with this I bought a pmdx-1parpci from pmdx and bought a c22 board from cnc4pc and I still can not get this mpg to work . Right now I can jog using the pendant only if I use the tab key and select the axis I want to jog none of the selector switches work and neither does the resolution switches (x1,x10,x100) . I have went as far as switching the ports around and using the 1 port to see if the mpg would respond to it and I get the same results . Does anyone else have a 2nd port using it for a mpg and have been successful???HELP PLEASE HELP
  8. #8
    Apr 2005
    Vanuatu
    Cool Re: Is there a way to test #2 port for mpg
    Read this one: https://cnc4pc.com/Tech_Docs/guide_f..._over_LPT2.htm
    Be aware that the brains affecting your use of MPG should be ENABLED!
    It was long time ago when I was using my DIY pendant on LPT2
    Attached Thumbnails Attached Thumbnails Is there a way to test #2 port for mpg-brn-png
  9. #9
    Nov 2007
    What about the brain u were using I have ran the one from cnc4pc and they dont work unless I'm doing something wrong I enabled them and nothing...can u send me the one u used
  10. #10
    Apr 2005
    Vanuatu
    This is a collection of brains that i've been using.
    https://cloud.mail.ru/public/3kLN/2bk7rWzio
    BTW are you Cad cam man
  11. #11
    Nov 2007
    Yes that would be me ... I hav ebeen on every fourm looking for some help and I am stuck I have tried everything to reinstalling Mach3 demo to a new pc , I sent the pendent back maybe thinking it was faulty I have been thru mach3 a million times looking for anything out of place , I am a fanuc guy by trade so this is all new if you come across any thing helpful please please shoot it my way
  12. #12
    Apr 2005
    Vanuatu
    Have you downloaded the file that I linked?
    If you have problem with Russian I might help you. Neither English nor Russian are my native speaking languages
