Need Help! Mach3 Error when spindle stops DoSpindleStop - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Mach3 Error when spindle stops DoSpindleStop
  1. #21
    Jan 2005
    Default Re: Mach3 Error when spindle stops DoSpindleStop
    Quote Originally Posted by legendarylarry View Post
    I had already tried that but I just tried it again. Still gave an error.
    You have messed up the files some where you need to write down all your configuration setting in Mach3 and the Smooth Stepper and do a clean install down loaded from the web site
    So delete remove Mach3 completely before you do a new install
    Mactec54
  2. #22
    May 2017
    PROBLEM SOLVED.?
    I finally received a message from Mach Support and Newfangled saying that the .066 version of Mach3 has been causing a lot of errors so it has been removed from their website and replaced with the .062 version which is more stable. I loaded it as Administrator and now everything is working smoothly again. Thanks, everyone, for all your help.
