G31 not working
Results 1 to 9 of 9
Thread: G31 not working
    Jun 2010
    Default Re: G31 not working
    It does not help that you have provided next to no information about your setup.
    Since some G31 instructions do work for you, I don't think the problem is in the Mach SW.
    Do you have limits set up?
    Cheers
    Roger
    Member DarkPhoinix's Avatar
    Apr 2019
    I am using a uc100 clone from usb to parallel using the mach3usb.dll on WIN10.
    Using directly on LPT and windows XP work GCODE G31!
    The machine is USB native and inside it has a PIC18F4550 chip the model of the card is a JP-382C.
    Is there a firmware for JP-382C with PIC18F4550 to make it work with mach3?
    In this way I could eliminate the clone UC100 USB / LPT converter.
    I want use the USB interface with windows 10 if possible.
    Thanks for your help.
    This is the problem:
    Jun 2010
    Sorry, can't help with the UC100 side of things. I use an ESS myself.
    I do know that there is a problem with many LPT converters. Mach3 under XP uses the LPT port in ways a bit different from a printer, and many adapters cannot handle the extra features needed.
    Cheers
    Roger
    Jun 2015
    Sweden
    Quote Originally Posted by DarkPhoinix View Post
    Get a real UC100 instead of a chinese fake one and your problem will be solved. (just my 2cents.)
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Almost all Chinese controllers have problems with probing.
    UCCNC 2017 Screenset
  7. #7
    Apr 2019
    Quote Originally Posted by ger21 View Post
    the probe work ! G31 is buged i am working to build a firmware for JP-382C with PIC18F4550.Need help for DLL for mach3
  8. #8
    Jun 2015
    Sweden
    Ask the manufacturer.
  9. #9
    do you still have drivers for chinese uc100
    clone ?
G31 not working
G31 not working
