M codes not working
Results 1 to 4 of 4
Thread: M codes not working
    Feb 2005
    Default M codes not working
    I have written a simple move program in note pad with the M30 command at the end.
    Saved it as a *.tap file .
    I load the program into Mach3 it comes up on the screen without the M30 command.
    I go back and edit the program and find the M30 command as the last line of the program.
    I run the program and it does not automatically rewind.
    Am I missing something in the setup of Mach?
    Member vmax549's Avatar
    Oct 2005
    Lady Lake
    Default Re: M codes not working
    Add an empty line AFTER teh M30 or a % .
    (;-) TP
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by johnd View Post
    As vmax549 has said add a % at the bottom and top of your program
    Mactec54
    Feb 2005
    Thank you
M codes not working
M codes not working
