i know that I should use Mach3 or mach4 turn profile for turning, and I think lathe is similar to turning, but there are few things that I do not understand, for example
in Turn I can control Step down of my spindle in order to control my Z movement, other wise one usually uses few Passes in order to cut the work piece, Do we have similar
thing in lathe in order to control the the X movement of My Cutter? Or it basically follows along my pattern of X axis with steady speed along of my Z Axis?
