motor sizing?
Results 1 to 3 of 3
Thread: motor sizing?
    Default motor sizing?
    Hello all! I'm new to the cnc retro world. And wanted to purchase a CNC trainer lathe. However I decided that it would be more beneficial in the future to build a 4th axis . I am curious about motor sizing in regards to weight holding/stopping/starting. I purchased my mill already converted and need to install limits and homing switches. And for some reason my mach 2 doesn't show any activity in the encoder portion of the screen. ( but that's a different issue)
    Any insight to proper sizing to hold ( start / Stop precisely ) will be greatly appreciated. I'm guessing my maximum weight to be 10#.
    I would only like to build this unit once. No upgrades for heavier product or motor inefficiencies.
    Member awerby's Avatar
    Apr 2004
    Default Re: motor sizing?
    Are you providing a planetary gear for this rotary axis, or just sticking a chuck on the end of a motor? With the gearing, you can use a much smaller motor than with the direct-drive plan. The ratio would factor in the torque required. The weight of your workpiece isn't that significant; it's the force required to turn it while cutting that makes more difference.
    Dec 2003
    There is a sizing program on the Kollmorgen site that used to be very useful for sizing.
motor sizing?
motor sizing?
