It sounds like you've got the anti-backlash settings set wrong.
Hello CNC geeks,
I am facing a problem hen using rapid movement G00 with mach3, when I use it with Y-Axis, it always add 25 mm, for example if I want Y-Axis to 7 cm, the DRO gives 72.5 mm, if I move from machine home 10 cm using G00, the Y-Axis moves 102.5.
Any Ideas?
- Problem- mach 3 problem
- Need Help!- mach 3 problem
- mach 3 problem
- Jog problem with Mach 2
