In Mach3 Motor Tuning and Setup
As ive updated my CNC machine with new Nema23 and Break Out Board etc, but still have the same CNC Timing Belt and gears!
When doing the Mach3 motor tuning and setup can you set your motors up manually by sound and sight alone?
Or do you need the calculations from the Nema23 and timing belts specs to do the motor tuning and set up? Ive done it already by Sight and Sound, but just seeing what the pros do in setting them up?
As I seen online people doing calculations based on their motors specs and belts and gears
But mine sound fine but im getting stuck on the Steps per Unit after the motor tuning but that issue is in another post
Thanks in advance
And I usually update the post once I get helped ????
