I used Inkscape to prepare my artwork (using inch as default unit). I then convert image to path and save as a SVG file. Next, I use MakerCam to generate gcode file (again i make sure I click "IN" (inch) as the default unit.
I then load the gcode into Mach3, again I go to Configurations and select "In" as native unit. So everything is in "Inches". The problem occurs when i run Mach3: it mills my image (just a letter W 1" tall x 1" wide) to about 1/8" x 1/8".
I have checked my times the native unit as "In" and save settings, Nothing works. I suspect the the stepper rate may be an issue.
I am desperately looking for any assistance or words of wisdom!
