Any way to force rotary axis to move only CW or CCW?
I'm trying to combat backlash in my timing belt driven 4th axis indexing. I know i can set it to short rotation so it only considers the final angular position and takes the shortest path, but I want it to always rotate one direction, even if it needs to rotate 270 degrees the long way instead of 90 degrees the short way. Fusion cam uses A0, A90, A180, and A-90 for 90 degree index points. I'm sure there's something I can do in the post processor to get the behavior I want, but wanted to see if there's a setting in mach3 I'm missing.
