Yes, there's a checkbox in General Config. Ignore M calls when loading.
Getting some strange behavior. I have 4 macros for my mill turn setup that i use within programs. One for activating spindle brake, one for deactivating spindle brake, one for activating collet closer, and one for deactivating collet closer. Before loading a program, if i have either my brake or collet closer active and load a program that has my deactivate macros within it, it will deactivate them while loading the program. While loading i can see it running through the code backwards and pausing momentarily on the deactivate macros and it releases the brake and collet closer. This is a problem for me especially with the collet closer. Sometimes i run a program and need to then run a second program with more operations. When the closer releases, i obviously lose the accurate position of the work. Why is mach3 running macros within code while loading it? The odd thing is, its only running deactivates within macros, not activates. In an opposite situation where my collet closer and brake are deactivated and i load a file that has activates in it, nothing happens while loading. Can i prevent it from doing this?
UCCNC 2017 Screenset
perfect! thanks
another related question, mach3 also disables all outputs with estop. Not as big of a problem, but would rather outputs stay active with estop. can i do that?
Don't have a copy of Mach3 here, but I doubt it.
Ok, not a huge deal. Only scenario is when servo spindle faults and alarms, chuck let's go. I'll consider setting up pneumatic chuck output backwards so it's normally closed and activating output opens it. Probably safer anyway in case of some failure that opens chuck during turning.
