Need Help! NEWBIE - Pins & Mach3 setup for CNC router
Results 1 to 13 of 13
Thread: NEWBIE - Pins & Mach3 setup for CNC router
    Member Andrew_Waldmen's Avatar
    May 2019
    Question NEWBIE - Pins & Mach3 setup for CNC router
    Hi everyone,
    I bought a used home-made CNC router together with PC. Everything worked fine, sometime later PC went crazy and without much consideration I replaced HDD for SSD and re-installed WINDOWS only to later realize that all the setup in MACH3 was gone. Since I have no knowledge of building CNC and I have no way of contacting previous owner who made this machine, I'm stuck with good non-working CNC.
    I watched some videos, read some articles and tried some pin variations, but no success.
    What I can tell, is I have MD882 board.
    Can anyone help me with setting up this machine again.
    Your help would me very much appreciated.
    Andrew.
    Aug 2016
    Default Re: NEWBIE - Pins & Mach3 setup for CNC router
    Quote Originally Posted by Andrew_Waldmen View Post
    Hi everyone,
    Andrew.
    Do you have the old HDD still? If so you should be able to connect that drive and get the XML file out of the MACH3 directory.
    Sent from my XT1635-01 using Tapatalk
    May 2019
    Nope, it's wiped!t
    Aug 2016
    Nope, it's wiped!t
    That does suck...
    The board you reference looks to be a motor driver..
    Do you know what breakout board it is. Can you take some pics
    May 2019
    Quote Originally Posted by truckeic View Post
    That does suck...
    Yeah sure.
    Please tell me You understand something here ))
    Attached Thumbnails Attached Thumbnails NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152929-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152932-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152935-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152938-jpg
    NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152944-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190516_152958-jpg
    Aug 2016
    Yeah sure.
    Ok your control board is a CNC4PC board. I cant see which version should be like C and some numbers. That would help some.
    The last pic you sent shows the motor outs. If you trace the org/wht pairs and the blu/wht pair from the Drivers (Looks like they are labeled X y and Z) back to the board you can figure out motor drives. the white wires are probably +5 volts and the blue is probably step and org is direction. You can look at the driver and verify. The 4 wires bottom right in picture 6 are probably spindle drives. You can trace them to the VFD. If you can get me a closer shot of the rest of the connections I can try and help further...
  7. #7
    May 2019
    You're amazing.
    Ill be in workshop Friday, will take more photos then!
  8. #8
    Aug 2016
    You're amazing.
    Your mill us way more than I have...
    But I have a CNC4PC board a C11G.
    You must have a 3phase spindle. I have jus a DC motor.
    Not amazing folks here helped me lots I only hope I can help..
  9. #9
    Aug 2016
    You're amazing.
    did you take any new pics
  10. #10
    May 2019
    Hi. Yeah, sorry, I did take more pictures. Hope they mean something more. Maybe You need something closer!?
    Attached Thumbnails Attached Thumbnails NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233736-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233746-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233748-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233753-jpg
    NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233755-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233757-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233802-jpg   NEWBIE - Pins & Mach3 setup for CNC router-img_20190605_233805-jpg
  11. #11
    Member john-100's Avatar
    Mar 2007
    uk
    later to night when I can use my own computer
    I'll download the breakout manual and try to workout which are the step signals and which are the direction signals to the stepper drivers
    I expect in Mach3's ports & pins
    pins 2 to 6 are the step and direction for your 3 axis drivers
    its not easy to see if 7 & 8 are for a 4th axis or possibly control a couple of relays for on/off & direction control of the spindle
    a wide shot of inside of the control box will help
    John
  12. #12
    Aug 2016
    Can you let us know what the model of the board is..
  13. #13
    Mar 2007
    uk
    the C11G rev5.3 looks like your breakout board
    the closest manual found so far with the discrete component opto -isolated relay
    C11-Multifunction_CNC_Board_Manual_Rev3.pdf
    possible step & direction connections to X , Y & Z drivers
    NEWBIE - Pins & Mach3 setup for CNC router-c11-rev3-jpg
    John
    PS
    looking at the 3rd photo in post 10
    the output status LED is off and the charge pump circuit is enabled
    in mach3
    pin 17 needs to be setup as on page 4 of the manual
