Need Help! NEWBIE - Pins & Mach3 setup for CNC router - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 13 of 13
Thread: NEWBIE - Pins & Mach3 setup for CNC router
  1. #13
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: NEWBIE - Pins & Mach3 setup for CNC router
    the C11G rev5.3 looks like your breakout board
    the closest manual found so far with the discrete component opto -isolated relay
    C11-Multifunction_CNC_Board_Manual_Rev3.pdf
    possible step & direction connections to X , Y & Z drivers
    NEWBIE - Pins & Mach3 setup for CNC router-c11-rev3-jpg
    John
    PS
    looking at the 3rd photo in post 10
    the output status LED is off and the charge pump circuit is enabled
    in mach3
    pin 17 needs to be setup as on page 4 of the manual
