Ok here we go.
I am trying to setup my 4th axis in mach3. This is what I have done so far with no luck.
I have got Mach loaded on my laptop, windows 10. I have 4 NEMA 34 steppers and drivers and 1 NEMA 23 on the 4th rotary axis plus driver.
Then I have a novusun 6 axis controller USB. I have setup X,Y plus slave as A axis and Z axis in ports and pins and motor tunning. I then setup my 4th axis as the B axis. The problem I have is that the 4th axis is not turning and the DRO is not moving when I am using the MPG in mach3. When I deactivate the slave A on the Y axis then the DRO on the 4th axis starts running with the Y axis but the motor still don't run.
i have watched a lot of videos on this subject and followed the instructions with no luck.
I just don't know what ells to try, please I will appreciate any help you guys and girls can give me.
Regards.
Paul.
