Tt depends which way the ratio was if it was ( 5 ) turns of the motor and ( 1 ) turn of the ballscrew or pinion, then you would of needed ( 5 x ) more steps/per, if it was the other way round then like ( 1 ) turn of the motor to ( 5 ) turns of the Ballscrew or pinion then you would of ( divided by 5 ) the number of steps per needed
Is that what you have in Mach3 step/per setting 25000
Mactec54
So the Gear boxes should work fine you just have to set up Mach3 steps/per and not the drives, what is in your drive is micro steps settings, not the steps/ per for your machine settings to different things, if you change the micro steps then yes you will have to change the steps/per in Mach3
So it has nothing to do with your drives they should be set at a number and left alone, the steps/per rev then have to be set in Mach3 for each axes Mach3 is the only place that you have to setup the step/per rev I think this is where it got messed up, so just set the micro steps in your drive and then set the steps per rev in Mach3 and you will be good to go
It looked like you had the steps per in Mach3 set at 100 if so then that would change to 500 if you put the gearboxes on
Mactec54
oke, but when i did that and i calibrated the axis in mach3 i got the twisting problem.
when i put the gear reductions in, i tried it first with the original drivers setting.
then i calibrated the axis in mach3 (settings page) and the "steps per" value mach3 gave caused the twisting of the gantry.
if i lower the "steps per" value or the velocity the problem goes away.
i then also tried other settings for the drivers (i went as low as 400 for the drivers).
but nothing worked, everytime i used the value giving by mach3 the problem was there.
Ok that is as I said micro steps settings that you have with your drive settings all your drives should be set the same and then you only do the steps/per in Mach3 this would be your only place to adjustment the steps per
If you change the micro steps in the Drive then you will have to recalculate the Steps/Per in Mach3 to get your exact axes movement
Mactec54
