Find out why steps are missing and fix that so you don't have the positional errors you mention.
I have a 30 minute NC program and need to re-home my 3 axis at mid point, hands off, using code. I miss enough steps that the end of the cut is out of position. If I slow down for accuracy, the time doubles. I need to make about 250 (30 min twice each pc), so the time is important. 3 D Carving, using Mach 3 & MeshCam. Thanks for the help, Edward
- Problem- 6m not homing
- Need Help!- Homing.. need help please
- Need Help!- Fanuc O-MD Homing problems Y Axis-Power up/ False Home/Slow homing
- Need Help!- homing
- HRT 210 homing
Maybe write a homing macro and call it mid program. There might be one available online somewhere.
But I agree with @he1957, it is normally better to fix the real problem.
Jim Dawson
Sandy, Oregon, USA
May be you need a UC100 from CNCdrive - motion controls or a SmoothStepper Board, either should help with this problem
Acceleration may be some of your problem this won't affect the time very much if you have it at a low setting, set to high can cause lost steps
The UC100 will give you better smoother running motors, so may even be able to use even higher speeds with this simple unit, if you get one of these make sure you are getting it from the manufacture or one of there resellers like CNC4PC as there are cheaper Chinese copies that don't work with there software plug in for Mach3
Mactec54
