Having trouble with the touch off function on my plaz after installing smoothstepper.
Hello all, I am trying to get my plasma running again. I have finally moved from the NVEM to a smooth stepper motion controller. However, the G31 Z-10 F40 command stalls out the program. I can Stop the program and hit cycle start and it will bypass the probing function and continue the code. I can lift the floating head and it will try to probe but it drives past the z switch. I also can enter this code into the MDI line and it works. (goes down hits the switch and stops.) I have moved away from Win XP and have a new setup.
New Mini PC celeron J1900 4 GB ram Quad core with windows 10. (8 GB of ram coming soon.)
Ethernet smooth stepper
New XML file
running the suggested version of mach3 and the smooth stepper plugin.
I am running the ST-v2 break out board.
I am running the Proma THC. Not this should matter!
The machine is working except the G31 function. Warp 9 is closed until the 6th so I am out of luck until then unless someone can help me here. Any suggestions would be greatly appreciated.
