My current setup is mach 3 operating a lathe. Recently I installed a mpg pendant from cnc4pc and everything seems to work however when I turn the dial to move the z axis it moves the wrong direction. Thinking it would be a simple fix I simply reversed the motor direction in ports and pins and now it's going in the correct direction when I rotate the dial but the DRO on the screen is opposite.
I tried to reverse it in home/limits but I cannot get the motor,DRO and mpg to all go in the correct direction. I even went as far as switching the a+/a- b+/b- on the drive and still no luck.
