Mach4 Axis 0 Commanded While Disable Help
Results 1 to 6 of 6
Thread: Mach4 Axis 0 Commanded While Disable Help
    Aug 2004
    Default Mach4 Axis 0 Commanded While Disable Help
    Hi Everyone
    I just got a copy of Mach 4 V2 and running a ESS
    I setup my motor and when i try to Zero I get a error message
    I did not have this error when i was running the demo
    Anyone have any ideas ??
    Thanks in advance
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Mach4 Axis 0 Commanded While Disable Help
    My guess is that you have a motor disabled, or not enabled, and your g-code is trying to move that motor.
    Go through your configuration very carefully..
    UCCNC 2017 Screenset
    Aug 2004
    Hi Gerry
    I only get that when i click on Go To Work Zero
    I double check everything, it jogs and go home perfect, i never tried to run code with it yet
    I even tried to make a new profile, and setup only one axis and i got the same thing
    Aug 2004
    I googles it and it seams like other people had this problem also
    Lots of the search results that go to the mach support page and you click on any of there links and it bring you to the main page
    Also there search feature don't work
    Seams like there is something wrong there
    https://www.machsupport.com/forum/in...?topic=35787.0
    Nov 2013
    I replied to your post on the Mach4 board on the 22.11.
    Did it not help?
    Craig
    Aug 2004
    Hi Craig
    Yes i did help Thanks
    You were right, my problem was i have motor 3 enable
    My X axis uses motor 0 and slave motor 3, so i though i had to enable motor 3
    when i took the check out everything was ok,
    Seams i still get the error from time to time but everything is working well
    probably something in the button scripts
