Is there a Mach3 configuration file to save as back up.
Results 1 to 1 of 1
Thread: Is there a Mach3 configuration file to save as back up.
    Activation process routermaker's Avatar
    Oct 2018
    Default Is there a Mach3 configuration file to save as back up.
    I just purchased a 5x10' Chinese CNC router with Mach 3 on an old PC as a controller. Is there a way to save all the current configuration settings in a single file in case the computer crashes? (or I want to change to another computer etc.) I don't want to be stuck setting it up from scratch. Any input appreciated.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Is there a Mach3 configuration file to save as back up.
    Just zip the entire Mach3 folder.
    The .xml file has all of the settings, but if you are using any custom macros, brains, or screens, you'll need those too.
    UCCNC 2017 Screenset
