Using STB4100 board with my own code
Results 1 to 5 of 5
Thread: Using STB4100 board with my own code
    Registered xrgo's Avatar
    Oct 2018
    Question Using STB4100 board with my own code
    Hello my friends!
    Some intro blah blah:
    I am really new in this stepper/servo motors stuff (and this forums)... and I find myself involved in a really simple project that consist in a 2 axis (cartesian) robot that just have to go from point A to point B, then to point C, etc (no complex curves and paths, nor Gcode) the fastest way possible.
    At first I used an Arduino with the AccelStep library, and its working! but I have some speed issues (slow, and when I use 2 axis at the same time its slower)...
    So I brought one of this Mach3 Controller Borads, this one:
    404 Not Found
    4 axis STB4100 motion card
    Because I need to use it in my laptop so no serial port
    I just received it! so I haven't connected any motor yet (weekend) but when I press stuffs in the Mach3 software the led blinks so it seems to be working xD.
    Now the real question:
    Since my application is really simple, I would like to write my own code (hopefully Qt C++) to control this board, But I couldn't find any Library/API/ProtocolDocumentation/etc on how to do it... I did find some info on how to add the mach3.exe to VisualStudio and communicate some stuffs to it using C# code... but still its depending on the mach3 software to be there. I want to write my own standalone software =)
    Is this even posible?
    thank you so much in advance!!
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Using STB4100 board with my own code
    You'd need to contact the manufacturer and see if they'll share the info with you. I wouldn't count on it.
    UCCNC 2017 Screenset
    Jun 2011
    Could you just use GRBL on an Arduino and write a PC control program to generate and send the G-code on the fly? All it would need to do is generate G1 X# Y# F# commands and send them over a USB serial connection.
    Nov 2013
    why did you buy a board without finding out if it could do as you wish?
    The only boards that I know of the are compatible with Mach AND have a low level on-board programming ability is the
    PoKeys 57CNC, Vital Systems Hicon (suitably activated...at a cost) or Gallil. The last two are expensive, around $1200
    and $2000 respectively.
    You might do some research on Dynamotion Kflop products, they have a Mach3 plugin but not a Mach4 plugin to my knowledge
    but also have onboard programming.
    Craig
    Oct 2018
    Thank you so much for the answers, yeah I didn't do my homework beforehand, but not a problem, its no so expensive... besides I have worked with numerous hardware stuff in the past and everything has an API or something I can work with, so I just assumed that it was going to be the case this time too =).
    I think I am going to research the arduino GRBL stuffs first!
    thanks again!!
