When the motor is locked, the drive is enabled. Most drivers are enabled by default.
How do I get Mach3 to get UC400ETH + HDBB2 to jog a motor?
I have just connected 1 motor on the Zaxis.
Then in the ports and pins I have enabled Z axis and set the Step as pin 6 and Dir as Pin 7.
I have TB6600 as stepper drivers.
Strangely, When I connect the enable to the driver (EN + and EN-) the motor shaft can be turned by hand but when I remove the enable to the driver the motor shaft cannot be turned by hand it is locked.
UCCNC 2017 Screenset
Ok, so I got it to work,
I had to load the Mill profile, and then the motor started jogging. So far I was using the Lathe profile. The mill profile already had the pins and ports all setup. So didn't need to do any settings as such.
However now when I jog X + or X - the motor only rotates in the clockwise direction. Any idea with the motor is not reversing? Is this an extra config in Mach3?
