Have a cnc router with mach3 and a ess smoothstepper interface, windows 7.
I just finished changing it over to a 2,2k spindle and a Huanyang VFD, It has a USB rs485 connection
between the computer and the VFD. All is working fine, except for one thing.
The spindle will not start yet by clicking on the spindle start button so
I start mach 3 and go into MDI and type S10000 & return then go to regular screen and I can turn on the spindle and
change speeds just fine, So I save settings. Also the spindle will run from the pendant ok.
Then I shut off mach3. When I start up mach3 again I need to go back and reenter the S10000
again before I can start the spindle again.
Is this normal or do I have something missing or configured wrong ?????
- Problem: MX3660, Can't change the spindle speed in Mach3
- Problem: MX3660 with Mach3: Can't change the spindle speed.
- Help chosing a spindle speed sensor to indicate spindle speed in mach3
- Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
- Spindle speed & Mach3
I'm talking about the spindle start button on the mach3 screen !!
Enter S10000 in the Initialization String in General Config.
UCCNC 2017 Screenset
Thanks for the message. I will try that tomorrow, Ill Bet that what I'm missing
