Mach3 no longer works in Windows 10 as of version 1803 - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 69 of 69
Thread: Mach3 no longer works in Windows 10 as of version 1803
  1. #61
    Member routalot's Avatar
    Dec 2003
    Default Re: Mach3 no longer works in Windows 10 as of version 1803
    I'm fairly sure you can run Linux in a virtual machine.Rather than doing so I would partition the hard drive and set up the system for dual booting to ease the load on resources.You don't need a huge amount of HD space and after a while you might be tempted to do more and more with the Linux installation.Gparted,which is easily found for most versions of Linux makes this easy and it can be done while running from a live Linux session.Its the way my homebrew machine runs and since I use LinuxCNC,the Windows partition doesn't see much action.One anomaly is that I use Freecad to create toolpaths and rather than return to the house for this I run the Windows version of Freecad under Wine.Not perhaps relevant to this section of the forum,but it might be of interest to some of you.
  2. #62
    Jun 2010
    Have you tried running AutoSketch v10 under WINE? That would be nice.
    Mind you, W7 & Mach3 with NO internet connection works fine on a production basis. Zero virus risk. File transfer by sneakernet.
    Cheers
    Roger
  3. #63
    Dec 2003
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    I don't have AutoSketch and consequently wouldn't know the answer.If you have it and could download an iso image of a Linux distro that will run live,you may be in a position to tell us if it does work.
    I agree with the comment about older versions of Windows running perfectly well.Among my acquaintances,there is one who runs a router using XP with no internet connection and another runs a mill that is programmed in DOS.They both produce useful parts.
  4. #64
    Jun 2010
    One of these days I will try that with Knoppix. I have the distro.
    I was running my machine in production mode until it died - using WXP. I had to 'upgrade' to W7. The vendor was sstill not keen to supply that.
    Cheers
    Roger
  5. #65
    Member Voltatek's Avatar
    Jul 2018
    Well... you should upgrade to MACH4 instead. maybe you will have better luck. https://voltatek.ca/92-cnc-software
  6. #66
    Nov 2019
    Installing or updating to the latest version of Windows 10.
    The Mach 3 will works on it.
  7. #67
    Nov 2019
    Quote Originally Posted by wobblinesssam View Post
    It is better to reinstall a latest version of Windows 10,by the way,making a Widnows 10 installation disk for installing it.
    https://www.windows10passwordreset.c...table-usb.html
    Do not download or install any non-secure files.
  8. #68
    Jan 2007
    Quote Originally Posted by MyGarageShop View Post
    I run Mach3 on a fast Windows 10 64 Bit computer using VMWare and Windows 7 32 Bit
    The Windows 10 has Virus Protection, Internet Access, and is regularly updated.
    The Virtual session of Windows 7 is locked down and runs perfectly and is unaffected by anything happening on the Windows 10 host as shown in this video
    In the video I am running Mach3 and simultaneously running a BobCad Simulation for a 750,000+ lines of GCode
    MyGarageShop
    https://mygarageshop.com/
    https://www.youtube.com/user/MyGarag...nnel/playlists
    Good tip!
    MM
  9. #69
    Member MyGarageShop's Avatar
    Dec 2016
    Quote Originally Posted by MicroMill View Post
    Good tip!
    MM
    If you have any questions feel free to message me
