Hi there
I am experiencing all strange things in my latest 2*4 CNC wood cutting Router project.
The latest problem is as follow:
All my four 750 Delta servo Motors were running nicely, at early stage of my project, but after few days after I tried to put all my cables in the E chain, and finishing my electrical Box and so on, I experienced a strange behavior from most of my Motors.
With my mach3 controller on I get Alarm (AL 06 ) from my motors Drivers
(It actually means that I should have the following problems
- The device has exceeded its rated load during continuous operation
- Control system parameter setting is incorrect
- The wiring of motor and encoder is in error
- The encoder of the motor is in erro
knowing that I have not even started to work with my machine, and I have not changed my parameters, Therefore I think that my problem should be because of the last 2 issues from the above list
Also If I turn off my controller as I start my motors at first all my Driver displays show the value if 00000 but, after few minutes the numbers on my Driver's Digital Display start to climb and/or Increase and all of a sudden at least one of the motors creates a sudden very Loud Sound and shake.
Please let me know what could be the cause of this, and How can I check for the cause of the problem, I think it should be some wiring problem but I do not know how to find it and consequently fix it.
regards
jhonansaro
