Have you looked at the 2010 screenset? I know it will do a circle and find the center.
It might get closer to what you want and the author was responsive when I reached out to him.
The 2010 screenset has made a huge difference for us for sure.
I presently have mach3 and big-tex blue screenset. I use the x-y center probe vbscript ( touch test) that is included in this screenset. I need to find someone that has the capabilities to modify the vbscript in order to meet the new requirements that I need for a special machining job. I am willing to give more details when someone get in contact with me, but in general, I need to find the 4 corners of a piece then calculate the center of it based on the 4 previous measurements.
For those wondering, I have tried contacting big-tex, but did not get any reply.
Thank you.
please reply through private message.
steve.
- Tormach digitizing probe to find center of a small circle, but bigger than probe tip
- Probe circular boss broke probe tip
- CMM Liquidation: Renishaw TesaStar Probe Head, Touch Probe, Motorized Indexable
- Need Help!- can you use a probe and mach3 to auto probe a part?
- TP-100 Probe - Compare Performance Motion probe to IMService probe
I actually need to do a learning of all four corners.... and would rather stay with the present screenset which works great for my needs... just need someone that can help expedite my needed modification... I could also learn vb, but would rather have someone already good at it...
Steve,
I am surprised Gerry "ger21" has not chimed in yet, give him a shout.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Back to square one...ger21 has no time to do it.... anyone ?
Can you not just use a probe to center of an external boss. X+ X- move to center of X then Y+Y- move to center of Y. That will put you in the center of the part. It can ALL be done in Gcode. No macro needed.
(;-) TP
I already use the corner finder script from the screenset.. I just need someone to modify it so it learns the 4 corners, then calculates the center of the square piece... All that because sometimes the pieces is not totally square and not always equal lenght and width... I need this because the machining job requires I flip the piece up side down and continue machining... because of that I always need to be in the center of the piece even when it is not perfectly cut to start with...
5-axis Kuka robot with water jet cutter for tool and using MasterCAM/RobotMaster to program. Works well to cut steel, aluminum, and armor materials.
I don't think it will do as you want it to but hey go for it. Normally if you do a 2 sided part you machine references into the first side that sets the exact Point of Origin for the second side
Good Luck
(;-) TP
Well, I ended up learning gcode and vbscript commands for mach3 and wrote the modification myself...
Cheers.
