I ended up finding a used computer on craigslist that had Win 7 installed. It's been working fine.
my older pc that I run my mach 3 mill on died looking to replace it but doesn't look like u can buy anything new to work with it? any ideas??
Thanks Ryan
If you add a motion controller like a UC100, you can run Mach3 on any modern PC.
UCCNC 2017 Screenset
I just brought a RCA tablet to try, has the latest Windows 10 on it, with the UC100 works like a charm, I loaded the Mach3 software and the UC100 plugin onto a Micro SD card which this tablet has a slot for
I will add other controls as well to see how far we can take one of these Tablets
Mactec54
thanks guys!!
Buy one of these and use any PCI-e slot:
https://www.ebay.com/itm/222897270029
Most of the computers with the PCI-e slot are not supported for running cnc control software, about 1 in 10 you may get to work, so in other words don't waste your time, people have had plenty of time to change from Parallel port computers
There is still mother boards out there to build a new computer if someone needed to have a Parallel Port, they are easy to build a simple computer like this
Mactec54
Any source for this other than the top of your head?Most of the computers with the PCI-e slot are not supported for running cnc control software
Yeah, I believe you're thinking of USB based parallel adapters.
Mactec54
Well, I'm sure there are a lot of weird drivers with weird compatibility issues, out there. I didn't mean to say that you don't know your stuff. But as far as Mach 3 and PCI-e parallel cards goes, I still maintain there shouldn't be any incompatibilities, as long as the card supports EPP.
I also agree: "people have had plenty of time to change from Parallel port computers." There are better ways now.
