needed:mach3 plugin dll for USBMach V2 - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: needed:mach3 plugin dll for USBMach V2
  1. #41
    Member Michael82's Avatar
    Nov 2007
    Default Re: needed:mach3 plugin dll for USBMach V2
    @ Brett32what is not working ? The motors work right ? what else do you need help with ?
  2. #42
    Nov 2007
    Quote Originally Posted by Brett032 View Post
    so ive spent the last week trying to get this working, i NEED HELP PEASE!!!
    using a v2.0 board, ive installed the settings as posted above. i can connect to the board as far as i know via mach3 i just cant make the motors move. ive tried every wiring configeration ive tried all pin numbers that i can think of and im out of ideas at this point.
    any help would be extremely appreciated!!
    So what is it you need help getting going ?
  3. #43
    Jan 2018
    I also got this USB breakout board, and used to control my CNC lathe.
    I connect the Input5 (Pin15) as index to get spindles RPM (use hall sensor to generate one pulse per revolution) ,
    but it return random RPMs from 10 - 1000, not usable to.
    When I use LPT breakout board, I got steady RPMs using the Pin15.
    it seems this USB breakout board cannot get spindle feedback RPM.
  4. #44
    Jan 2018
    Anyone have new driver or solution to get it work with spindle index?
  5. #45
    Member Farshad1368's Avatar
    Jan 2021
    Hello. Friends, please help me. My job has been disrupted due to this problem. Does anyone have the exact wiring of this controller? Send it to me on WhatsApp. + 989192558632
  6. #46
    Nov 2007
    Quote Originally Posted by Farshad1368 View Post
    What board do u have ??
    See attachment file
    Attached Files Attached Files
  7. #47
    Nov 2007
    Quote Originally Posted by wy6688 View Post
    I was able to the spindle index working but mach 3 would lock up after i jog z axis I tried switching the driver and the problem followed so I bought new drivers still does it . I have to shut down mach 3 restart it and it will work for a little bit and it does it again . I finally switched to ess smoothstepper and all the problems went away
  8. #48
    Jan 2021
    Quote Originally Posted by Michael82 View Post
    See attachment file
    Wow, how I was looking for such a thing. You are the best friend. Thank you ??????
  9. #49
    Nov 2007
    Yes sir glad to help let me know if there is anything else I can help with
  10. #50
    Jan 2021
    Hello friend
    . My device is in the settings stage. The first problem is that I do not know the settings of the drives and software. The second problem is that the road controller port locks all the axles when I disconnect it from the PC, and the axles are released when I connect it. Please help
  11. #51
    Jan 2021
    https://s4.uupload.ir/files/????????_??????_8nhm.jpg
    https://s4.uupload.ir/files/drufelcnc_usbcnc5a_l30.png
    https://s4.uupload.ir/files/????????_??????_ry91.jpg
    https://s4.uupload.ir/files/whatsapp-image-2020-11-21-at-11.36.09-pm_y93e.jpeg
    This is a photo of the parts and connector I used
  12. #52
    Oct 2006
    ITALY
    Hi. quick question for the owners of this board: do you see "actual speed" in mach3 during travel or works? I see only 0.00 and so I don't know the real speed of the cnc.
    Thanks a lot.
    (escuse for my bad english, I'm from Italy)
  13. #53
    Member Mecanix's Avatar
    Aug 2019
    Hi Michael, sent you a PM asking how you've sorted the spindle index pulse. Just got myself involved with a V2.1 board too and have yet figured out why it doesn't work. Tried to send a clean 2%, 5%, 10% duty cycle signal using a function generator and that doesn't reach out to M3 via all the BL Mach3 dll drivers I could find. Next step is probably to hook a logic analyzer on the usb (hid) protocol and reverse engineer that STM32 firmware and the plugin entirely :/
    In a meantime, if anyone else managed to get this spindle index pulse working please do share. Bet many who have this board are pretty stuck... (just how the dev of that plugin thought we were doing rigid tapping and lathe threading?!)
  14. #54
    Member PedroMuska's Avatar
    Jul 2022
    Esquema de ligação do PWM
    Cf300
    Pino 1 Porta FWD
    Pino 5 Output 01
    Inversor parametrizado para 0-10v igual para potenciometro
    Pino 7 - AVI
    Pino 8 - ACM
    Pino 9 - 10v
  15. #55
    Jul 2022
    Cf300
    Pino 1 Porta FWD
    Pino 5 Output 01
    Pino 7 - AVI
    Pino 8 - ACM
    Pino 9 - 10v
    - - - Updated - - -
    Quote Originally Posted by shadeyinka View Post
    I have the BL-USBMach V2.2 board. I have been able to get it working with stepper motors.
    I have been trying desperately to control the PWM output of the board from mach3 to no avail. Can you please send the configuration settings?
    Cf300
    Pino 1 Porta FWD
    Pino 5 Output 01
    Pino 7 - AVI
    Pino 8 - ACM
    Pino 9 - 10v
  16. #56
    Registered Rainman229's Avatar
    Sep 2004
    nj
    These are files that came with mine. They work. Only issue I had with wiring is, I had to flip dir and pulse wire for it to run. Not total sure if it was me messing up in wiring at first or the print is wrong.
    The second issue is this board will not support backlash offsets. Now looking for one that will. I've gotten as much as i could out of mechanically but need that last little bit.
    http://www.rainman229.com
