Could be 100 different things. But I'd guess it's an issue with the step and direction signals and your drives.
When I build my router I decided to run my Y axis by using two ballscrews. Each screw has it's own motor and own stepper controller. I went to Mach3 settings and slave the Y and A axis together so they work at the same time. And here is the problem. Sometimes they work together tight way and most of the time they don't. I tried so many settings and still same problem. If I won't fix it I'm going back to one ballscrew on Y axis , I'm so frustrated. What might be the problem?
UCCNC 2017 Screenset
Could it be temperature fault? It was working great when it was warm in the garage. But when the temp droped to 28 degrees this is when it start to happen
