shearder
when you pause, program remain in ""run"""... when you press stop, or enforced stop after pause.. program remember where you stopped and return to the previous node..
with pasue will continue at that exact point, no matter it is between two node somewhere..
it is good if you want lower or raise zero.. means cutting deeper or lifting tool out a little....
Sent from my computer using my keyboard and my fingers :-)
