I have been trying to figure out a few things about AlphaCams post processor lately also.
Hello..
Can anyone help with a postprocessor for Alphacam......
your help appreciated..
cheers
Frans
I think Frans got a post from Bob Campbell.
UCCNC 2017 Screenset
I can do them.
But I do charge - relatively inexpensive when compared to vendor prices.
Interested? I will need to know machine, control and basic axis configuration.
Andy NC
Andy
Originally Posted by Andy NC
How much is it for a postprocessor Alphacam to NUM750 ??
£200 GBP NC code will be perfect (i.e. right first time)
Can trade via web and PayPAL for security.
Let me know what you think
Andy
Andy
Can you make me a postprocessor AlphACAM - Record 2 NUM750.
I have the old one made for DOS. Is that of any help ?
If it was a DOS post processor for the DOS version of AlphaCAM (which was called APS) it will automatically be converted once AlphaCAM is loaded. No need to buy a new one.
Simply ensure the old LicomDAT folder is on the PC you are installing AlphaCAM onto and the installation procedure should take care of everything.
If its not for APS then its useless to me. I can make a new one in this case.
You will need to send me details of the machine...
Number of spindles
Number of vertical drills
Number of X axis horizontal drills
Number of Y axis horizontal drills
Saw unit details etc.
Does the machine have 2 vacuum zones?
I will be happy to send test NC programs from the post processor for you to test.
Andy
Andy
I send you all info. that you need.
it is better to send directly to your emailadress
My emailadress
lerken@c2i.net
can you mail me???
[IMG]Data[/IMG]Originally Posted by Andy NC
Do you need more details ??
Andy NC,Originally Posted by Andy NC
Looking for alphacam post for Anilam 5300 Mk controller .
On standard 3 axis milling MC.
Can you make a postprocessor out of the data I gave you ?
lerken
No problem just send me a couple of sample NC programs,
Need to show me a wide range of functions e.g. lines, arcs, drilling/pecking/tapping cycles, radius compensation,
Cost is £200 GBP. Will accept payment via paypal.
Waitng on your reply
Andy NC
Andy
Num 750. Poor quality photocopies but enough to get started.
Will send a sample program very soon.
Andy NC
Andy
Andy,
You can contact me directly at info@rockwellprecision.com
Can I email sample progs directly to you and arrange payment.
Many Thanks.
Andy NC,
Attached is Manual containing G codes and canned cycles for my
machine.Wont be using any pocketing cycles for machining just using canned
cycles for drilling,peck drilling,boring,tapping and reaming.
Can you let me know me you have enough information,sorry for the delay as
I was away.
Tuohye
Hello.
I have a problem with the post postprocessor. I am working a pade uni5 with alphacam 2012R2. so when i am working with 5 axis and c axis goes up to 95o the machine stop working.
can anyone tell me which is the command that I have to use in the nc code, in order to change the interpolation of the C and A axis when the machine comes to overstroke and stops running?
I need the command to rotate the C axis to -180 or +180 and at the same time to mirror the A axis.
andy nc ,
need a post for alphacam to busellato evolution 2.3
email is aaronangell77@gmail.com
Hola Andy NC ,leí por el sitio que vos podés hacer un postprocesador para alphacam , tengo un SCM tech z25 que utiliza xilog plus y no puedo hacer que funcione con alphacam , me podrías decir si podés y cuánto vale hacer el posprocesador.
Mi correo es federicoespamer@yahoo.com
