I am using the code below to align the sheet above on the plasma cutting machine.
If GetUserLED(1010)=1 Then
SetUserLED(1010 ,0)
End If
dx = GetOEMDRO( 800 )
dy = GetOEMDRO( 801 )
Pi = Atn( 1 ) * 4
If Abs( dx ) > Abs( dy ) Then ' horizontal, near X axis
angle = Atn( dy / dx )
Else ' vertical, near Y axis
angle = Atn( - dx / dy )
End If
angle = angle / Pi * 180
ret = MachMsg("A = " & roun(angle) & "° Confirmar Alinhamento", "Axis Rotation", 4)
If ret = 6 Then ' Yes
SetOEMDRO(118, angle) 'Code("G68X0Y0R" & angle)
Message("A = " & roun(angle) & "°")
SetUserLED(1011,0)
DoButton(17)
While IsMoving()
Wend
angleF = GetOEMDRO( 118 )
Code("G69")
Code("G0 X104.14Y10.15")
While IsMoving()
Sleep(10)
Wend
SetOEMDRO(118, angleF)
While IsMoving()
Sleep(10)
Wend
DoOEmButton(1007)
While IsMoving()
Sleep(10)
Wend
DoOEMButton(170)
Sleep(100)
DoOemButton(160)
End If
The code works well but when I need to pause the cut and then cut again the machine loses the position of the axes and presents the error radius to end of arc differs from radius to start.
Has anyone experienced this problem, what may be happening, what configuration can I change to solve the problem?
