Need Help! Does not complete cut, torch stops early
Results 1 to 1 of 1
Thread: Does not complete cut, torch stops early
    Member pdxmaverick's Avatar
    Oct 2020
    Default Does not complete cut, torch stops early
    Noobie, first post.
    That being said I think I have gotten pretty far.
    Instructable DIY Plasma table.
    Using SheetCAM and Mach3.
    Problem:
    Pretty simple drawing, Sheet cam shows the cut lines with arc in and arc out.
    When running the gcode it goes to cut a small bolt hole it looks like a C. The torch completes the movement but the torch turns off before the end of the cut.
    It does this on all of the cut. I found a post of similar issue and said it was Spindle CW spindown delay. I have tried setting them to 0. I have tried immediate shutoff.
    Suggestions?
    I will try to upload all of my setting and photo.
    Thanks in advanced for any advice.
    Cheers
    Attached Thumbnails Attached Thumbnails Does not complete cut, torch stops early-img_2445-jpg
    Attached Files Attached Files
