Hello all, So im in the process of building a cnc plasma cutter, i have the frame and gantry built now im working on the electronic side of things. I ran into a problem with mach 3.
Setup im using:
Dell desktop running windows 7 (32 bit) Nema 23
DM542A driver Breakout board ( dont have the model number right now)
Mach 3 (demo at the moment)
So ive been pulling my hair out becasue ive been having issues with the stepper motor not moving when i jog within mach 3. I checked my wiring a thousand times, mach 3 settings, drivers, Bios, power, etc... Then i discovered that for some reason the stepper motor will work with mach 3 mill but even with the same settings will not work with mach 3 plasma program.
Can anyone figure this issue out? Its driving me mad. I will post better pictures of the set up later , im currently at work. Thanks everyone
Sent from my LM-Q710.FG using Tapatalk
