Having an issue with my plasma table. Just completed the build and have most kinks worked out. I am having an issue with my drives faulting out when the plasma fires, it will cut fine until it gets closer to where the controls and plasma are then it faults every time it fires. I can move it back to 0,0 and it will run until it gets to a cut so far out, or if I try to start in that location it will fault. Any help would be appreciated
