The shift= direction bypasses the % of max jog that you can see by hitting the tab key and looking at the pendant like popup to the max setting
If the shift =+direction doesn't go any faster, you may have to raise the max motor speed under motor tuning. Just make sure you don't set the motor tuning any faster than the machine will go.
Mike
